4 piece backs
http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=9756
Author:  crich [ Sun Dec 10, 2006 1:43 pm ]
I have some walnut that I would like to use. I can only resaw 6 inches, and I've seen three piece but I never saw a picture of a 4 piece. I checked the arhives but didn't see anything. Should I turn the outside pieces to flare out toward the bottom and and a triangular shape in the middle? How would I brace it? Thanks Clinton
Author:  Rod True [ Sun Dec 10, 2006 2:44 pm ]
I really don't know, but I can't see why you couldn't make a 4 piece back.
I would think that you would put a strip over each joint and just brace as normal, cutting each strip to allow the brace to run through.
(Also, this bumps your question up )Rod True39061.9480208333
Author:  JohnAbercrombie [ Sun Dec 10, 2006 7:14 pm ]
There was an item in the GAL Quarterly 'American Lutherie' #76 Winter 2003 by Alain Bieber on this topic. He suggested a method of cutting the plank on the diagonal to maximize the usable wood. The accompanying pic shows slightly wedge-shaped pieces in the center of the back.
I was just reading issue #76 earlier this evening.
You can get back issues via the GAL website.
Send me a PM if you need more info on the article.
Author:  Bobc [ Sun Dec 10, 2006 8:09 pm ]
Here's a picture of a 4 piece Curly Macassar set that I bookmatched. I think it looks pretty darn good.
Author:  Colin S [ Sun Dec 10, 2006 8:23 pm ]
Multi piece backs are fine, I have used up to 13 pieces for backs (OK that is in a lute ) but even Torres went up to 6 piece back, and if it was good enough for him...... We are spoilt now with the availability of tonewood. If 6 inches is all you can cut then go ahead double book match like the Bob's set above and it will be great.
Author:  martinedwards [ Sun Dec 10, 2006 8:34 pm ]
My backs are all piece as I have the sam resaw restrictions.
parallel joins are easier to keep track (and clamp!!) of than wedges!!
Author:  crich [ Mon Dec 11, 2006 12:08 am ]
I never thought of the problems of glueing parallel joints,thanks! I need to cut my wood 3/8" so I can cut it again to get the bookmatch.
That is some serious zoot Bob!
I keep telling myself that I'm just a beginner, but I keep hearing about all these great articles from GAL.
So other than the strips, the rest of the bracing goes as normal? CLinton
Author:  LanceK [ Mon Dec 11, 2006 12:38 am ]
Here are a few shots of a four piece cocobolo 0-12 im making.
Author:  crich [ Mon Dec 11, 2006 5:01 am ]
WOW! That is pretty Lance. I see you brace as normal. Thanks for sharing. Clinton
Author:  martinedwards [ Mon Dec 11, 2006 5:50 am ]
4 piece walnut dread
4 piecs oak mini jumbo
4 piece walnut bouzouki
4 piece walnut mando
5 piece walnut doubleneck
none have fallen apart yet!!!
Author:  Michael McBroom [ Mon Dec 11, 2006 6:09 am ]
[QUOTE=Hesh1956] Four piece backs are very much something that you can do.
In fact LMI used to sell some pretty sharp Mad Rose that was made from four piece backs.[/QUOTE]
I have a few sets of this stuff. It is well matched, and you'd never know each plate was two pieces just by looking at it. So, yeah, I'd say this should be very doable, all the more so if you can get a good match.
Best,
Michael
Author:  Kirt Myers [ Mon Dec 11, 2006 6:33 am ]
Here's two 4-piece walnut backs I'm working on now. Putting reinforcements on all 3 joints makes for a little more work and they're probably not needed. But it is cheap insurance.
I did a double book match.
Kirt
Author:  bob J [ Mon Dec 11, 2006 6:53 am ]
Lance,
Sorry, that back and the work are not up to your standards. I, on the other-hand, have no standards and will be more than happy to be the repository.
Author:  LanceK [ Mon Dec 11, 2006 7:18 am ]
well do Bob
